Actual This Period Units
Actual This Period Units field
The labor, nonlabor, and material units used during this financial period.
If period performance is stored, the calculation is Actual Units minus the sum of the stored Actual This Period Units fields for all previous periods.
If the period performance is not stored, Actual This Period Units is the same as Actual Units.
