Adding Activity Resource Estimates
You can plan resource usage by adding resource estimates to activities.
To add resource estimates:
  1. On the "" Navigation Menu, expand "" Projects and click Activities.
  2. On the Activities page, select an activity and click the Assignments detail window.
  3. In the Assignments detail window:
    1. Assign a resource or role to the selected activity.
    2. Add the Planned Units/Time, Planned Units, Planned Cost, and Planned Duration columns to the detail window.
    3. Select an option or enter a value for each field.
