Configuring Activity Resources
You can configure resource information for activities, including the Planned Units/Time, Proficiency, or Rate Type for a resource.
To configure activity resources:
- On the
Navigation Menu, expand
Projects and click Activities. - On the Activities page, select an activity and click the Assignments detail window.
- In the Assignments detail window:
- Select a resource.
- Add or remove the columns you need to configure to the detail window.
- Select an option or enter a value for each field.
Tip:
- You can also configure activity resources from the Open Requests forResources portlet of the Dashboards page.
- When you create, delete, or modify a resource assignment, your changes are automatically saved when you select another activity. You will not be able to undo the changes after selecting a different activity.
