Adding Risk Response Plans
Add one or more response plans to a risk to plan alternative activities that might reduce the probability of a risk occurring, or to reduce the impact of the risk.
  1. On the "" Navigation Menu, expand "" Projects and click Risks.
  2. On the Risks page, click a risk, and then click the Response Plans detail window.
  3. On the Response Plans detail window:
    1. Click "" Add "" and select Response Plan.
    2. In the ID field, type a response plan ID.
    3. In the Name field, type a name for the new response plan.
    4. In the Response Type field, select a response type from the list.
  4. On the Risks page, click Save.
    After you decide which response plan you are implementing, select the Active option next to the appropriate response plan.
