Developing a Risk Response Plan
Once you have identified a risk for your project, you can then create a risk response plan to help manage the project risk. A risk response plan includes a name for the plan and response plan action items. You can create multiple risk response plans for a risk each with multiple response action items. When you determine which plan will best meet the project needs, select the Active option next to the appropriate response plan. One response plan must always be active.
To develop a risk response plan, complete the following tasks:
  1. Adding Risk Response Plans
  2. Adding Risk Response Plan Action Items
  3. Assigning Activities to Risk Response Plan Action Items
