Anticipated Finish
Anticipated Finish field
The expected finish date of the project, EPS node, or WBS level used during the planning phase. This date is manually entered and is not affected by scheduling.
If there are no children elements, the anticipated finish is the finish date listed for the item in the table.
The Anticipated Finish date is used as the Finish date if there are no activities assigned to the project or WBS.
