Anticipated Start
Anticipated Start field
The expected start date of the project, EPS node, or WBS level used during the planning phase. This date is manually entered and is not affected by scheduling.
If there are no children elements, the anticipated start is the start date listed for the item in the table.
The Anticipated Start date is used as the Start date if there are no activities assigned to the project or WBS.
