Applying Filters
Apply filters to a project to specify the data you want to display. You can add user-created filters or select from the list of standard filters.
To apply filters:
- On the
Navigation Menu, expand
Projects and click Activities or EPS. - On the Activities or EPS page:
- Click the Views list and select a view to which you will add the filters.
- Click
Customize View.
- In the Customize View dialog box, click the Filtering tab.
- On the Filtering tab:
- Select to match all applied or any applied.
- In the filter list, select the option for each filter you want to apply.
- Click Save and Apply.
Tip:
- If you have Contributor module access, either assigned as a resource or activity owner, applying the My Activities filter will have no affect on the activity list display because your access is already restricted to your assigned and owner activities.
- You can also click the View menu and select Filters from the Filters submenu to open the Customize Filters dialog box. You can apply filters from this dialog box.
- If you want to save the application of these filters to the view, click Yes in the Primavera P6 dialog box which opens when you navigate away from the page.
