Configuring EPS View Filters
You can modify or create filters. These filters can then be applied to several different EPS views.
To customize EPS view filters:
- On the
Navigation Menu, expand
Projects and click EPS. - On the EPS page:
Tip:
You can also customize EPS view filters from the Customize Filters Dialog Box. Click the View
menu, click the Filters submenu, and select
Filters.
