Assessing Project Health
You can use dashboards to quickly determine the health of a project and identify areas where you might need to focus attention.
To assess project health:
- On the
Navigation Menu, expand
Dashboard. - On the Dashboards page, select a dashboard.
- On the dashboard, expand the Project Health portlet to see a quick summarization of the project.
Tip:
If the portlet is not available, add it to the dashboard.
