Customizing Project Statistics
Customize project statistics to define how columns and groups are displayed in a Dashboard.
To customize project statistics:
  1. On the "" Navigation Menu, expand "" Dashboard.
  2. On the Dashboards page, select a dashboard.
  3. On the dashboard, click Customize.
  4. On the Customize page, click the Content tab.
  5. On the Content tab, expand the Project Performance section and click Customize for the Project Statistics portlet.
  6. In the Customize Project Statistics dialog box, click the Columns tab.
  7. On the Columns tab:
    1. Configure the columns in the Selected Columns list.
    2. Select options from each list.
  8. In the Customize Project Statistics dialog box, click the Group tab.
  9. On the Group tab, repeat the following for each level you want to customize:
    1. Select options from the lists for each Level.
    2. Select or clear the options.
  10. In the Customize Project Statistics dialog box, click Save.
  11. On the Content tab, click Save and Close.
