Assigning a Base Calendar to a Resource Calendar
Assign a base calendar to apply all the exception days (for example holidays and other work or nonwork days) from the base calendar for the selected resource calendar.
To assign a base calendar:
- On the
Navigation Menu, expand
Administration and click Enterprise Data. - On the Enterprise Data page, expand Resources and click Resource Calendars.
- In the Resource Calendars pane:
- Expand Personal Calendars or Shared Calendars and select a calendar.
- Click the Summary tab.
- In the Base Calendar field, click
Select.
- In the Select Base Calendar dialog box, select a calendar.
- Click Select.
