Assigning a Resource to a Resource Calendar
Resources can be assigned a personal calendar or a shared calendar. A resource is assigned to a personal calendar when creating a personal calendar.
To assign a resource to a shared calendar:
  1. On the "" Navigation Menu, expand "" Administration and click Enterprise Data.
  2. On the Enterprise Data page, expand Resources and click Resource Calendars.
  3. On the Resource Calendars page:
    1. Expand Shared Calendars and select a shared calendar.
      Click the Used By tab to view resources currently assigned to the shared calendar.
    2. Click "" Context and select Assign Resource.
  4. In the Select Resource dialog box:
    1. Select the resources to assign to the calendar and click Select.
  5. On the Resource Calendars page, click Save.
Tip:
If you need to remove a resource from a shared calendar, assign a different calendar to the resource from the Resources tab on the Resources Administration page.
