Assigning a Resource Team to a Resource
Perform these steps to assign a resource team to a resource. You can do this from either the Resources tab or the Resource Teams tab. Use this method if you want to view all the resource teams assigned to a single resource.
To assign a resource to a resource team:
  1. On the "" Navigation Menu, expand "" Resources and click Administration.
  2. On the Resources page, click Resources.
  3. On the Resources tab:
    1. Click the name of the resource you are assigning to a resource team.
    2. Click the Resource Teams detail window.
  4. In the Resource Teams detail window, click Assign....
  5. In the Select Resource Team dialog box:
    1. Expand either the Global or User category, and select a resource team.
    2. Click Select.
  6. Click Save.
Tip:
To view all resources assigned to a particular resource team, assign a resource to a resource team from the Resource Team tab.
