Assigning a Resource to a Resource Team
Perform these steps to assign a resource to a resource team. You can assign a resource to a resource team from the Resource tab or the Resource Teams tab. Use this method if you want to view all resources assigned to a particular resource team.
To assign a resource to a resource team:
  1. On the "" Navigation Menu, expand "" Resources and click Administration.
  2. On the Resources page, click Resource Teams.
  3. On the Resource Teams tab, expand either the Global or the User group and click a resource team name.
  4. In the Resources detail window, click Assign....
  5. In the Select Resource dialog box:
    1. Select a resource and click Select
      Use Ctrl+click or Shift+click to select multiple resources.
  6. Click Save.
Tip:
To view all resource teams assigned to a particular resource, assign a resource team to a resource from the Resources tab.
