Creating Resource Teams
Create resource teams to reduce potentially large resource pools into smaller, more meaningful and manageable groups.
To create a resource team:
  1. On the "" Navigation Menu, expand "" Resources and click Administration.
  2. On the Resources page, click Resource Teams.
  3. On the Resource Teams tab:
    1. If you are creating a global resource team, select the Global group and click "" Add.
      If you are creating a team only for your use, select the User group and click "" Add.
    2. In the Name field, double-click and type a resource team name.
  4. In the Resources detail window, click Assign....
  5. In the Select Resource dialog box:
    1. Select a resource and click Select
      Use Ctrl+click or Shift+click to select multiple resources.
  6. Click Save.
