Assigning a Role Team to a Role
Using role teams can simplify resource planning. You can do this from either the Roles tab or the Role Teams tab in the Resource Administration area. Use this method if you want to view all role teams assigned to a particular role.
To assign a role to a role team:
- On the
Navigation Menu, expand
Resources and click Administration. - On the Resources page, click Roles.
- On the Roles tab:
- Click the role you are assigning to a role team.
- Click the Role Teams detail window.
- In the Role Teams detail window, click Assign....
- In the Assign Role Team dialog box:
- Expand either the Global or User category, choose a role team, and click Select.
- Click Save.
Tip:
You can also assign a role to a role team from the Role Teams tab. Use this method if you want to view all roles assigned to a particular role team.
