Assigning Calendars to Resources
Assign a global or resource calendar to a resource to determine when the resource is available to work.
To assign a calendar to a resource:
  1. On the "" Navigation Menu, expand "" Resources and click Administration.
  2. On the Resources page, click Resources.
  3. On the Resources tab:
    1. Click a resource.
    2. Click the Settings detail window.
  4. In the Settings detail window, click "" Select in the Calendar field.
  5. In the Select Calendar Name dialog box:
    1. In the View calendar type list, choose to view either global or resource calendars.
    2. Select a calendar.
    3. Click Select.
      If you want a personal calendar for the resource, click Create Personal Calendar. You can also create personal or resource calendars from the Enterprise Data page.
  6. Click Save.
Tip:
  • You can perform the same procedure from the Calendars field on the Resources tab.
  • Configure My Calendar to edit exceptions to your personal calendar. To view a personal calendar, the resource must be a user in the system.
