Assigning Locations to Resources
Assign locations to resources so you can report on resources by location in Primavera Analytics.
To assign a location to a resource:
- On the
Navigation Menu, expand
Resources and click Administration. - On the Resources page, click Resources.
- On the Resources tab, click the General detail window.
- In the General detail window, click
Select in the Location field. - In the Select Location dialog box, select the appropriate location and click Assign.
- Click Save.
Tip:
- You must create locations before you can assign them.
- You must have the Edit Resources global privilege to assign locations to resources.
