Configuring Timesheet Reporting for Resources
Configure timesheet reporting if some users will report progress using the Timesheets tab in P6 Team Member Web.
To configure timesheet reporting for a resource:
- If the resource is not already defined as a user in the system:
- Add the user.
- Assign the resource to the new user.
- Enable access to P6 Team Member Web by selecting the Team Member module access options.
- Enable access to timesheets by selecting the Timesheet module access option.
- Configure timesheet options for the resource if you are implementing non-automatic approval.
Tip:
For faster setup of timesheet reporting, configure settings on the Timesheets page of the Application Settings pane, located on the Administer menu. Use these options to designate a default approval manager whenever you create a new resource.
