Assigning Projects to a Portfolio
When comparing portfolios on the Portfolio Analysis page, you can assign a project to the selected portfolio in either half of the page.
To assign a project to the selected portfolio:
  1. In the context selector, select "" Portfolios.
  2. In the context selector:
    • Click Open Portfolio to select a group of projects by portfolio type, EPS node, or project code.
    • Or choose a portfolio in the Most Recently Used list.
  3. On the "" Navigation Menu, expand "" Portfolios and select Portfolio Analysis.
  4. On the Portfolio Analysis page, click "" Assign a project to this portfolio
  5. In the Select Project dialog box select a project and then click Select.
Tip:
You cannot assign a project to a portfolio when displaying a scenario; you must select <Latest Data>.
