Defining Performance Thresholds
To help you assess the relative performance, earned value, index calculations, and other metrics for a WBS, project, or portfolio, you can set performance thresholds. These thresholds capture the current calculations, variances, and metrics and re-route them into one of four ranges or "buckets" as follows:
Exceptional: Indicates that a WBS, project, or portfolio is exceeding expectations.
Acceptable: Indicates that a WBS, project, or portfolio is performing within an expected range.
Warning: Indicates that a WBS, project, or portfolio needs attention and is performing below expectations.
Critical: Indicates that a WBS, project, or portfolio requires significant corrective action.
To define your own performance thresholds:
- Click the User menu and select My Preferences.
- On the My Preferences page, click Global tab.
- On the Global tab:
- Expand the Performance Threshold section and then expand Performance, Earned Value, and Index.
- For each parameter, shown with its color-coded visual indicator, enter a threshold value. For lists, select a value from the list.
- Click Save and Close.
Tip:
If any logical constraints are not satisfied by your selections, a message appears at the top of the page. For example, if you set a warning to 25 days late, a critical threshold cannot be set to 10 days late; logical constraints require that critical thresholds be greater than warning thresholds. Correct the thresholds and try saving again.
