Assigning Related Items to Issues
You can assign related documents and issues to an issue.
To assign related items to an issue:
  1. On the "" Navigation Menu, expand "" Projects and click Issues.
  2. On the Issues Management page, expand a project and select an issue.
    • In the Relate Documents detail window, click Assign... and select documents from the dialog box.
    • In the Relate Issues detail window, click Assign... and select issues from the dialog box.
Tip:
  • To remove a document or issue, click "" Context next to the name of the item and select Delete.
  • The instructions in this topic assume that the content repository is configured.
  • The Related Documents dialog box will only display documents of the selected project.
