Customizing Project Issues
Customize the display of project issues to define how their available columns, filters, grouping, and sort options appear in the user interface.
To customize project issues:
  1. On the "" Navigation Menu, expand "" Projects and click Issues.
  2. On the Issues page, click Customize.
  3. In the Customize Project Issues dialog box:
    1. Click the Columns tab and use the common controls to configure the Selected Columns list.
    2. Click the Filtering tab and show all available issues or define a filter.
    3. Click the Grouping tab and configure the grouping lists and options.
    4. Click the Sorting tab and configure the sorting lists and order.
    5. Click Save.
Tip:
You can also customize project issues from the My Issues portlet of the Dashboards page.
