Configuring Project Issues
Configure project issues to update issues that have been identified for a project.
To configure project issues:
- On the
Navigation Menu, expand
Projects and click Issues. - On the Issues Management page, expand a project and click an issue:
- In the General detail window, configure the fields and lists.
- In the Codes detail window assign issue codes.
- In the Related Documents detail window assign related documents.
- In the Related Issues detail window assign related issues.
- Click Save.
Tip:
You can also configure issues from the My Issues portlet of the Dashboards page.
