Creating Project Issues
Create project issues to identify problems within a schedule that must be addressed before the project can be completed.
To create a project issue:
  1. On the "" Navigation Menu, expand "" Projects and click Issues.
  2. On the Issues page click "" Add.
  3. In the Select Project dialog box, select a project for the issue and click Select.
  4. On the Issues page, configure the issue fields and click Save.
Tip:
  • The issue name must be unique relative to the names of any other issues assigned to the same project, WBS, or activity.
  • You cannot add an issue to a project that is checked out or locked. You also cannot create issues for template projects.
  • You can also create project issues from the Issues detail window of the Activities page or EPS page, or the My Issues portlet of the Dashboards page.
