Assigning Resources or Roles to Projects or WBS Elements
You can assign labor resources or roles to projects and their WBS elements during the planning phase of the project. You can assign resources if you know who will most likely be performing the work. When you assign a resource to a project or WBS element, the resource is assigned without a role allocation.
In long-range planning, you may choose to assign a role to a project or WBS and then staff the role with a specific resource at a later date after the activities have been defined.
To assign a resource or role to a project or WBS element:
  1. On the "" Navigation Menu, expand "" Resources and click Planning.
  2. On the Planning page, expand a project, and click the project or WBS row.
  3. Click Assign... "".
    • Select Resource if you know which resource you want to assign.
    • Select Role if you know which role you want to assign.
    • Select Assign Resource using Search if you want to search for a resource to assign.
  4. On the Planning page, clear the Committed option if the assignments are not definitely committed to the project.
    When calculating resource availability for high level resource planning, only the committed assignments are considered.
  5. Click Save.
Tip:
  • You cannot assign material resources on the Planning page.
  • Once a role is assigned, you can then define search criteria for the assignment to assist with future staffing of the role. Defining search criteria enables you to more accurately identify the type of resource required to staff the role. To define search criteria, click the Yes or No link in the Search Criteria field. The Yes or No link indicates whether saved search criteria exist for the assignment.
