Searching for a Resource to Assign
You can specify search criteria to select a suitable resource to assign to a project or WBS element. When you assign a resource using a search, the Search Criteria column on the Planning page provides a link to the search criteria used to assign the resource.
To search for a resource to assign:
- On the
Navigation Menu, expand
Resources and click Planning. - Select a project or WBS element.
- Click Assign...
and select Search For a Resource to Assign. - In the Assign by Search dialog box:
- In the Assign by Search results:
- Select the resource to assign.
- Select Assign.
