Assigning Role Rates
Use this procedure to assign rates to roles. You can assign multiple rates to roles to reflect price changes over time. You can assign time-varying rates for roles to more accurately determine total resource (and activity) costs. You can also assign role work limits to define the maximum amount of work units the selected role can perform in a single work period.
To assign role rates:
- On the
Navigation Menu, expand
Resources and click Administration. - On the Resources page, click Roles.
- On the Roles tab:
- Click a role.
- Click the Units and Prices detail window.
- In the Units and Prices detail window:
- Click
Add. - In the Effective Date field, double-click to open the calendar and choose a date and time to start the new rate.
- In the Max Units/Time field, double-click and type the maximum work units per time for this resource.
- In the appropriate price fields, double-click and type an amount. The default time period is price per hour unless you specify another time period.
- Click
- Click Save.
