Assigning Roles to Multiple Activities
Perform these steps to assign roles to multiple activities at one time.
To assign roles to multiple activities:
- On the
Navigation Menu, expand
Projects and click Activities. - On the Activities page, select one or more activities to which you want to assign roles.
- Click
Context and select Assign Role. - In the Assign Role dialog box select one or more roles and click Select.
- Click
Tip:
- To select more than one item, use Shift+click to select contiguous items or Ctrl+click to select individual items.
- To view all roles and resources assigned to an activity, select the activity, then click the Assignments detail window.
