Configuring Activity Roles
You can configure role information for activities.
To configure activity roles:
- On the
Navigation Menu, expand
Projects and click Activities. - On the Activities page, select an activity and click the Assignments detail window.
- In the Assignments detail window:
- Select a role.
- Add or remove the columns you need to configure to the detail window.
- Select an option or enter a value for each field.
Tip:
You can also configure activity roles from the Open Requests forResources portlet of the Dashboards page.
