Assigning Successor Relationships
You can assign successor relationships to the activities in your project.
To assign a successor relationship:
- On the
Navigation Menu, expand
Projects and click Activities.
Tip:
- Only Finish to Start relationships are created in the Assign Relationships panel. To create other types of relationships create the relationships in the Gantt View. Alternatively you can create the relationships in the Assign Relationships panel and then change the relationship type manually in the Relationships detail window.
- You can also change an existing relationship in the Successors detail window. To choose a different successor, select the Activity ID field in an existing relationship and choose a different activity from an open project. The Relationship type and lag will be maintained if you select a new successor.
- When selecting a predecessor or successor activity, you can choose from activities in the open projects only.
