Configuring Predecessor Relationships
Configure predecessor relationships to define lag or relationship type.
To configure predecessor relationships:
- On the
Navigation Menu, expand
Projects and click Activities. - On the Activities page, select an activity whose predecessor relationships you want to configure and click the Relationships detail window.
- In the Relationships detail window:
- Select a predecessor relationship.
- Add or remove columns as needed to configure to the detail window.
- Select an option or enter a value for each field.
- Click Save.
