Available To
Available To field
Indicates the user access to various views and dashboards throughout the application.
Global: All users can access the view or dashboard.
User: Only you, the current user, can access the view or dashboard.
Multiple Users: A select group or list of users, including you, has access to the view or dashboard.
Selections vary based on your location in the application.
