Base Calendar
Base Calendar field
The global calendar that is assigned to the calendar to determine work days, nonwork days (for example, global holidays), and calendar exceptions.
For example, multinational corporations will have one or more global calendars per country to represent global holidays for each region. Exceptions are used when the standard work day is modified.
