Checking In Documents
Check in a document when you are finished with it. You must check in a document to lift the lock that a check out places on a document.
To check in a document:
- On the
Navigation Menu, expand
Projects and click Documents. - On the Documents page, click the Project tab.
- On the Project tab, select a checked out document and click
Check Out options and select
Check in. - In the Check In dialog box:
Tip:
- When an item is checked out, it will have a
green check mark beside it.
- You can also check out documents from the My Documents portlet of the Dashboards page.
