Checking Out Documents
Check out a document to save a copy to your local machine or another specified location. Checking out a document locks the document to prevent others users from making simultaneous updates to it. When a document is checked out, users can still view and download the document, but they cannot modify, delete, or check it out.
To check out a document:
- On the
Navigation Menu, expand
Projects and click Documents. - On the Documents page, click the Project tab.
- On the Project tab, select a project and click
Check Out options options and select
Check out.
Tip:
- To undo a check out, click Undo Check Out on the Check Out options menu.
- When an item is checked out, it will have a
green check mark beside it.
- You can also check out documents from the My Documents portlet of the Dashboards page.
