Configuring Activity View Columns
Configure activity view columns to specify which columns are visible in the grid or table.
To configure columns:
  1. On the "" Navigation Menu, expand "" Projects and click Activities.
  2. On the Activities page:
    1. Click "" Customize View.
    2. In the Manage Views dialog box, click the Columns tab.
    3. On the Columns tab:
      • Customize the Selected Columns list using values from the Available Columns list.
      • Click Save and Apply.
Tip:
  • You can display a maximum of 30 columns.
  • You can customize activity view columns from the View menu. Click the View menu and select Columns.
