Configuring Activity Views
Configure activity views to define how you see activity data. Activity views affect the filters, grouping, and columns that are applied to the Activities page. Detail window visibility is also affected by the selected activity view.
To configure activity views:
- On the
Navigation Menu, expand
Projects and click Activities. - On the Activities page:
Tip:
- You can modify any view you create. You can only modify global activity views if you have the appropriate security privileges.
- You cannot save modifications you have made to a multiple user view unless you created it. If you need to save a multiple user view that another user created, save it as a new view.
- When you copy and paste a user, you also copy the user's views.
