Configuring Activity View Filters
You can modify or create filters. These filters can then be applied to several different activity views.
To configure activity view filters:
  1. On the "" Navigation Menu, expand "" Projects and click Activities.
    1. On the Activities page:
      • Click the Activity View list and select an activity view to configure.
      • Click "" Customize View.
    2. In the Manage Views dialog box, click the Filtering tab.
    3. On the Filtering tab:
      • You can modify a filter.
      • You can create a filter.
      • You can apply filters.
      • Click Save and Apply when finished.
Tip:
  • The My Activities filter displays all project activities you are either assigned to as a resource or designated as the activity owner.
  • For the Activities occurring within (blank) days or Activities finishing within (blank) days filters, specify a number of days.
  • You can also customize activity view filters from the View menu. Click the View menu and select Filters from the Filters submenu.
