Configuring Activity View Sorting
Configure activity view sorting to determine the order in which activities will be displayed within a grouping band.
To configure sorting:
  1. On the "" Navigation Menu, expand "" Projects and click Activities.
  2. On the Activities page:
    1. Click the Views list and select an view to configure.
    2. Click "" Customize View.
    3. In the Manage Views dialog box:
      • Click the Sorting tab and configure the sorting options in each section.
      • Click Save and Apply..
Tip:
To sort by a column it must be showing in the view.
