Configuring Dashboard Filters
For multi-user and global dashboards, the dashboard owner can elect to restrict users from changing the dashboard filter. If the dashboard owner selects this option, the dashboard displays data according to the specified dashboard filter. If the dashboard owner does not select to restrict users from changing the dashboard filter, users can select their own filter for the dashboard.
To configure dashboard filters:
  1. On the "" Navigation Menu, expand "" Dashboard.
  2. On the Dashboards page, select a dashboard.
  3. On the dashboard, click "" Filter by at the top of the tab and select a filter from the dialog box.
Tip:
You can also change the filter from the General section on the Content tab of the Customize page.
