Configuring Dashboard Layout
You can arrange the portlets on the dashboard to accommodate your viewing preferences.
To configure the layout of the portlets on a dashboard:
  1. On the "" Navigation Menu, expand "" Dashboard.
  2. On the Dashboards page, select a dashboard.
  3. On the dashboard, click Customize.
  4. On the Dashboard Details page, click the Layout tab.
  5. On the Layout tab:
    1. Select the Narrow or Wide option for each portlet to make it one or two columns wide.
    2. Select a portlet and click the up, down, left, or right arrows; or, drag and drop the portlet to change its position.
    3. Click Save and Close.
