Showing and Hiding Dashboards
Determine which of the dashboards available to you should appear on your Dashboards page as its own separate tab.
To show or hide dashboards:
- In the context selector, select
Dashboard and then click Manage Dashboards. - On the Manage Dashboards page:
Tip:
- There is no need to save your changes on this page; they are automatically applied.
- Click Delete to permanently delete the dashboards you created or have permissions to delete.
Caution:
Caution Exercise caution whenever you delete dashboards. Other users might be using them and should be notified before you make such a change.
