Configuring Data Limits Settings
Data limits allows you to specify the maximum number of levels for hierarchical structures. You can also specify the maximum number of baselines and activity codes that can be included in a project, the maximum number and size of stored images and various other maximum limits.
To configure data limits settings:
- On the
Navigation Menu, expand
Administration, then click Application Settings. - On the Application Settings page, click Data Limits.
- On the Data Limits page:
- Click the up and down arrows for each item to set maximums.
- Click Save and Close.
