Configuring Earned Value Settings
Configure earned value settings to specify defaults for calculating earned value.
To configure earned value settings:
  1. On the "" Navigation Menu, expand "" Administration, then click Application Settings.
  2. On the Application Settings page, click Earned Value.
  3. On the Earned Value page:
    1. In the Technique for computing performance percent complete section, select an option.
      If you select the Custom % Complete option, use the up and down arrows to select a percent.
    2. In the Technique for computing estimate to complete (ETC) section, select the first option or select one of the other four options to define a formula.
      If you select the PF = option, click the field and type a value to be equal to PF.
    3. In the Earned Value Calculation section, choose an option from the list.
    4. Click Save and Close.
Tip:
You can select only one option in each section.
