Configuring EPS View Access
Configure EPS view access to define who can see a view.
To configure EPS view access:
- On the
Navigation Menu, expand
Projects and click EPS. - On the EPS page:
- Click the Views
menu and select Manage Views....
- Click the Views
- In the Manage Views dialog box:
- Select a view in the Multiple Users group or hover over the Multiple Users group, click
Context and select Add to create a new view. - Click the Access tab.
- On the Access tab, select one or more users and add them to the Selected Users list.
- In the Manage Views dialog box, click Save.
