Configuring EPS View Gantt Chart
Configure Gantt chart options to determine how the chart will display.
To configure EPS view Gantt chart:
- On the
Navigation Menu, expand
Projects and click EPS. - On the EPS page:
- Click the Views list and select a view.
- Click
Customize View. - In the Customize View dialog box, click the Gantt tab.
- On the Gantt tab, configure the options and click Save and Apply.
Tip:
You can also configure the Gantt chart from the View menu. Click Gantt Chart Options on the View menu and click the Gantt Chart tab.
