Configuring EPS View Gantt Chart Bars
Configure the bar settings for the Gantt chart view on the EPS page. You can specify options for up to three bars per project.
To configure EPS view bars:
  1. On the "" Navigation Menu, expand "" Projects and click EPS.
  2. On the EPS page:
    1. Click the Views list and select a view.
    2. Click "" Customize View.
    3. In the Customize View dialog box, click the Bars tab.
    4. On the Bars tab select an existing bar or label or click "" Add "" to add a new bar or label.
    5. Select a bar or label.
      • If you selected a label, configure the Field, Height, and Color.
      • If you selected a bar, configure the Bar Type, Height, and Bar Color.
      • If you selected a bar, choose whether to Show Progress on the bar. If you chose to show progress, select a Progress Color and Progress Style for the bar.
    6. Click Save and Apply.
Tip:
  • You can configure up to three bars. Set at least one bar to Current Bar.
  • When you display many bars at once, for greater ease in reading the bar labels and identifying a specific bar, you might find it helpful to vary the position of the label on each bar.
  • You can also customize EPS view bars from the View menu. On the View menu, click Gantt Chart Options, then click the Bars tab.
