Configuring History Settings for Primavera Analytics
Use this task to configure the type of data stored in Primavera Analytics and in what time interval.
To configure history settings:
  1. On the "" Navigation Menu, expand "" Projects and click EPS.
  2. On the EPS page:
    1. Select a project.
    2. Click "" Context and select Set Project Preferences.
    3. In the Project Preferences dialog box, click Analytics & Services.
    4. On the Analytics & Services page:
      • On the History Level list, choose how to store historical spread data.
      • If you selected Project or WBS, select an option on the History Interval - Project or WBS list.
      • If you are running ODI, select an option on the Data Warehouse Update Frequency list.
    5. Click Apply.
